donwatson Posted January 23, 2014 Report Share Posted January 23, 2014 Hi a Newbie here looking for information. At present we use a Mitsubishi Alpha 24 brick. This unit has 15 Inputs and 9 Outputs and we we currently use 13 Inputs and 8 Outputs, we have no plans to exceed these I/O's (at present). Can anyone advise about a suitable Unitronics PLC/HMI that we could use as a substitute ? I hope to contact a U.K. supplier in the morning and ask the same question, but as I will also need the appropriate Programming Software etc. I thought I would join the forum here and start asking my stupid questions. Thanks for listening. take care Don W Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted January 25, 2014 MVP 2023 Report Share Posted January 25, 2014 Assuming your inputs are DC, you can use a Jazz JZ20-R31. Look up the specs on the website and see if it will fit your needs. Hopefully you have the Mitsubishi program. Joe T. Quote Link to comment Share on other sites More sharing options...
donwatson Posted January 25, 2014 Author Report Share Posted January 25, 2014 Thanks Joe, I have been in contact with a UK distributor and he has recommended :- JZ10-11-R31 V130-33-R34 V350-35-R34 I have downloaded the catalogue and will have a browse but I think his recommendations should fit the bill o.k. When we use the Mitsubishi we need the GT Screen Designer to produce the screen graphics and download to the GOT 1000 and we need the Alpha 24 Programmer to produce and download the program to the PLC. At the moment we only use the FBD process on the programmer but I suspect we will need to produce ladder diagrams when using the Jazz ? Thanks again take care Don W Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted January 27, 2014 MVP 2014 Report Share Posted January 27, 2014 All the Unitronics units are programmed in Ladder. However the Vision family has several function blocks as well, that are inserted as ladder elements. Since you are using a HMI panel, then possibly the V130 or V350 are a better fit than the Jazz. With either the Jazz or V130/V350 the one software package is used to program both the ladder and HMI screens, which should give you a saving in time and complexity. Software is free to download: U90 Ladder for the Jazz Visilogic for the V130/V350 Programming cable is as follows: JZ10-11-R31 - purchase JZ-PRG (Or JZ20-R31 has a USB programming port, the JZ-PRG not required) V130/V350 includes serial programming cable, you need a physical RS232 serial port or USB to RS232 adaptor. Quote Link to comment Share on other sites More sharing options...
