prebone Posted February 13, 2014 Report Share Posted February 13, 2014 Hi! I've made a Function that calculates flow to quantity a day. I want to use this as a UDFB several times, for all of my flowmeters (30), but only the first of them gives an output-value?? Can't a UDFB only be used more than once? Quote Link to comment Share on other sites More sharing options...
Saragani Posted February 13, 2014 Report Share Posted February 13, 2014 The whole point of a Function/UDFB is to be used more than once with different parameters. For it to work, you should avoid the use of Global tags in the UDFB if those Global tags are needed to be different on each call (You should rather define them as Function-In/Out and pass them as a parameter). Without seeing your code, I cannot know what you are trying to do, or what you are doing wrong. Quote Link to comment Share on other sites More sharing options...
