tester2 Posted December 2, 2010 Report Share Posted December 2, 2010 Hello im a newbe on modbus and remote i/o i wont to use a moxa iologik e1214 with 6relay outputs. i added a attachment for e1214 Modbus/TCP Default Address Mappings. can someone here give me an example how to acivate/deactive a coil in this unit using modbus tcp. im trying to learn this as im a new in this area and just using it to learn about plc control system. i would be very greatfull for any example. after reading the help file for unitronics i know that i have to init card and set ip. but i would like to have one coil example so i can try learning this since i do not understand the setup as it is now. Quote Link to comment Share on other sites More sharing options...
tester2 Posted December 2, 2010 Author Report Share Posted December 2, 2010 nn Quote Link to comment Share on other sites More sharing options...
