mcmahoney Posted December 2, 2010 Report Share Posted December 2, 2010 Is there a way to delete the files from an SD card? I am writing files to the DT folders and would like to delete these files using the ladder logic. Quote Link to comment Share on other sites More sharing options...
Jas Posted December 2, 2010 Report Share Posted December 2, 2010 Please try the "Delete SD File" function block. It allows you to specify the folder of the the file you would like to delete on the card. SD --> SD File Utilities --> Delete SD File Quote Link to comment Share on other sites More sharing options...
