Maurice118 Posted February 26, 2014 Report Share Posted February 26, 2014 Are there any images available to integrate in the HMI displays like there was on VisiLogic. I only could find Tanks. Thanks, Maurice 1 Quote Link to comment Share on other sites More sharing options...
Saragani Posted February 27, 2014 Report Share Posted February 27, 2014 If you browse for an image, then you should see in the File Browser Dialog a shortcut to the UniPics (see attached screenshot) You have pipes, motors, pumps etc. The tanks you were talking about are probably the tank element (which also have a progressbar/bargraph inside it, so it can be linked to a Tag) Quote Link to comment Share on other sites More sharing options...
Maurice118 Posted February 27, 2014 Author Report Share Posted February 27, 2014 Thanks, yep you are right they are indeed tank elements. I already found the images. However the folder is missing some transition images. For example pumps or motors every different pump or motor is only in one color available. Maurice Quote Link to comment Share on other sites More sharing options...
HigHTech Posted February 27, 2014 Report Share Posted February 27, 2014 Are there any images available to integrate in the HMI displays like there was on visilogic. I only could find Tanks. Thanks Maurice Maurice: there is another option if you are looking for high quality 3D render images. Please visit www.plc-apps.com I will like to hear what do you think about the libraries. Quote Link to comment Share on other sites More sharing options...
t0r3r0s Posted January 8, 2018 Report Share Posted January 8, 2018 On 2/27/2014 at 4:20 PM, HigHTech said: Maurice: there is another option if you are looking for high quality 3D render images. Please visit www.plc-apps.com I will like to hear what do you think about the libraries. Greeatings , have someone to know where can i finde this librari free Quote Link to comment Share on other sites More sharing options...
