Password field not working.
Maurice118
If I create a password field in a HMI display, it doesn't update the tag when I input my password. It stays empty. I now solved it with creating a text entry in the HMI display and let it disappear once the password is entered. A working password field would be prefered instead of this work a round.
Thanks
Maurice
Hi, the password element you've talked about does the other thing around. It doesn't insert the text you have entered into a tag, but rather validate the entered text with the value of the tag (You can define actions of Fail and Success to that element, so if the user have entered a correct password, then it will do something, for example, load a different screen).
The feature you are talking about is masking the text box. UniLogic is going to have a masked Numeric box in one of the upcomming versions, but I'll suggest a feature to also mask a Text Box if needed.
  • Upvote 1
  • 1 month later...
  • 1 year later...
