mike@synoptic Posted March 15, 2014 Report Share Posted March 15, 2014 Need to download to customer PLC in field via SD card - I know what the PLC serial number is from the label on the PLC - can I get the PLC ID (SDW 9) from that serial number? Quote Link to comment Share on other sites More sharing options...
EduMarg Posted March 31, 2014 Report Share Posted March 31, 2014 Hi Mike Are you trying to connect to the PLC remotely to download the data using SD card suite? Is this connection Ethernet or serial? Way do you need the PLC ID? If what you are looking if for the PLC name, you must go to info mode of the PLC and in system Sw version you will find the name. Can you please give us more detail about your problem? Please write to us to support@unitroncis.com Thank you. Best Regards, Quote Link to comment Share on other sites More sharing options...
