mckruger Posted April 2, 2014 Report Share Posted April 2, 2014 Hi how do you set your default start-up display with VisiLogic Quote Link to comment Share on other sites More sharing options...
EduMarg Posted April 2, 2014 Report Share Posted April 2, 2014 Hello. In VisiLogic the default Start up display is the Display called !Start-up-Display iof the !Star-up module on the HMI. You can add a net in the Main module Main rutine that will jump to your desier HMI screen at PLC start up. Attached a small logic that will help you with this. If you want more information you can contact Unitronics Support at support@unitronics.com Best Regards,Eduardo. M call HMI screen at system start up.bmp Quote Link to comment Share on other sites More sharing options...
