thierry Posted December 5, 2010 Report Share Posted December 5, 2010 Hello I have a gas burner that I want to program. It is equipped with a security card with an input 220 volts for startup. From a simple relay for the power increase, and another relay for the power drop. I want to run manage the secondary injection of gas and pwm valve controlling the carbon potential and with a lambda sensor. PID control, recipe management simple with segment (5 to 10), control the process by recording curve. I've never done programming, I would use a V1040. It would nice for a programmer to help me in my spot. Thank you, very much thierry Quote Link to comment Share on other sites More sharing options...
Stein Yair Posted December 21, 2010 Report Share Posted December 21, 2010 Hi, How can I help you? Quote Link to comment Share on other sites More sharing options...
