Aslam Moolji Posted May 2, 2014 Report Share Posted May 2, 2014 We have connected an encoder to M91 2 R1 and cannot get the reading in the Memory Interger Value. We are getting a value which keeps on incrementing as we rotate the Shaft of the Encoder. Can anyone send me a sample prog so that i can check if any mistakes have been made. The same programme is working with the same encoder programmed a few months back. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted May 2, 2014 MVP 2023 Report Share Posted May 2, 2014 Post your program so we can have a look. Click the "More Reply Options" under the posting area to access the "Attach Files" buttons. Joe T. Quote Link to comment Share on other sites More sharing options...
