pascal
download error
When downloading a project to a V570, with the option to syncronize the time between PC and PLC the UniDownloader (ver 5.0.07) will fail to do !
first it will syncornise the time, but the PLC stops running and the only way to "run" the PLC is via the sofware visilogic.
I'm not able to restart the PLC with the Debug screen.
The only way the downloader works is to upgrade only the application
(did not tried to download the bin,boot and OS)
all software (on PC and PLC) are the latest version
Hello Pascal,
First, try to run Unidownloader as an administrator (right click on the file icon-->"Run As Administrator"). Now try to download the project.
If still not successful, please send the Unidownloader project to support@unitronics.com for further analysis.
Hello Pascal.
For getting the PLC to go back to RUN mode after download, please define the User Interaction options in Unidownload Designer as marked in the attached image.
