alera729 Posted May 13, 2014 Report Share Posted May 13, 2014 Hello, I hope that you are doing well. I am programming a new project in VisiLogic and was wondering if there was a way to change numeric variable properties on the fly. This is because I want the customer to be able to choose between SI and Imperial Units, and I need to change some number displays and numeric entries accordingly. I tried hiding some variables when a "unit" bit is set, but I cannot place one number on top of the other, nor are there binary numeric variables. Is there an easy way to do this that I am missing? Thank you very much in advance. Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted May 14, 2014 Report Share Posted May 14, 2014 Hi! To implement a multiple unit numeric variable you can do the following: 1. define a numeric variable. add a numeric link and in the text box select "String from Library". You should define a library string ID variable. 2. Enter "String Library" from the project tree and double click on an empty space in the table. In the pop up window fill the text for the units you need. 3. Write the logic for the conversion between units. Use a button to select between units and perform the caluculations in every unit change. After you converted the value use the function "Set String Library" to select the unit that will be displayed. I attached a small application I made for demonstration. It's a unit converter for pressure units - ATM to PSI. It's pretty straightforward and I believe you will find it easy to implement. Pressure Convertor.vlp Quote Link to comment Share on other sites More sharing options...
alera729 Posted May 15, 2014 Author Report Share Posted May 15, 2014 Exactly what I needed, works perfect. Thank you! Quote Link to comment Share on other sites More sharing options...
