56flyboy Posted May 20, 2014 Report Share Posted May 20, 2014 I have a project that requires me to use FTP to send and retrieve .csv files from an FTP server. I know someone has written a program to send files via FTP for Visilogic, and I am currently working with the example that tech support sent me (still have to work out some bugs) but has anyone here used FTP to retrieve files via FTP and put them on the SD card?Thanks for your helpKurt Quote Link to comment Share on other sites More sharing options...
Jon1711 Posted February 17, 2017 Report Share Posted February 17, 2017 Was there ever an answer to this? I am looking for a way to import a Data table using FTP. I can export files from the SD card using TCPIP commands to a USB stick but am struggling to import from the USB stick to the SD card... I use a RETR command in the FTP-CMD block but where does that file go? If anywhere? Thanks, Jon Quote Link to comment Share on other sites More sharing options...
Ofir Posted February 19, 2017 Report Share Posted February 19, 2017 Hi Jon1711, Attached is an example for sending file from Vision PLC to FTP Server. Using SD card suite - SD card Explorer you can copy files from the PC to the Vision PLC. V570_FTP_client.vlp 2 Quote Link to comment Share on other sites More sharing options...
