gvlasso Posted June 11, 2014 Report Share Posted June 11, 2014 This is my first post so I didn't have the time to introduce myself. Anyway I am starting my first project with a V570 and an snap in IO card in order to monitor and control the process of a drying oven. I viewed the corresponding webinars and I think I got the main idea about Visilogic (My previous knowledge about ladder and PLC programming is minimum). Anyway when I insert a configuration PID FB in my project and trying to compile the code, I get the error mesagge that PID Config is not supported by Color PLC or/and V130-33. Am I missing something too obvious ? Any help is welcome, Thanks in advance, Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted June 12, 2014 MVP 2023 Report Share Posted June 12, 2014 Can you post your program? Joe T. Quote Link to comment Share on other sites More sharing options...
gvlasso Posted June 13, 2014 Author Report Share Posted June 13, 2014 The truth is that the program was at its very best beggining ( - |SB2| - PID Config ). So there wasn't much to send. Fortunately I already got a reply from Unitronics support and the problem is already solved. The solution is that I had to use the functions blocks (for run PID, configuration, etc) from PID Autotune menu rather than the PID menu. Anyway the project is proceeding and I am sure that I will come up with other questions for help and advice. So, stay tuned . Thanks a lot for the interest Joe. Quote Link to comment Share on other sites More sharing options...
