janm7462 Posted June 20, 2014 Report Share Posted June 20, 2014 Hello, I'm using UniLogic and I want to copy only a column for example recipe names. In the VisiLogic software this is possible with a function under data tables. How do I do this in UniLogic? Thanks, Jan Martijn Lenselink Quote Link to comment Share on other sites More sharing options...
s.pratt Posted June 20, 2014 Report Share Posted June 20, 2014 Hello Jan, thank you for using our Unitronics Forum. You can use our "Read Row from DTI" function block under our Data Table: Indexed tab in UniLogic. This will copy a row of the data table into a struct. I would copy it into a "buffer struct", then copy the ASCII string of the Column (from the buffer struct) to where ever you want to move the information to. Then increment the index of the data table and do the same for the rest of the rows. Let us know if this helps. Quote Link to comment Share on other sites More sharing options...
