Eyal Koren 21 Report post Posted June 22, 2014 Hi all,This is an open invitation for you to suggest new ideas and thoughts for Unilogic UDFB's.It is very important for us to keep track of our customers needs. As part of this agenda we want to create and develop useful tools for your benefit.These UDFB's will be attached to the next releases of Unilogic.Please feel free to suggest any idea that seems useful.Thank you Share this post Link to post Share on other sites
YINGD 1 Report post Posted November 16, 2014 I'm not sure if this is the sort of suggestion you are looking for on this subject but I'll put it here anyhow. I think it would be great to have some statistical calculation functions. If there was the ability to read a vector/array of values and determine the statistical profile, that would be excellent! The values that would be most helpful I think would be those that are available in Excel when using the statistical analysis tools such are seen here (http://www.real-statistics.com/descriptive-statistics/descriptive-statistics-tools/ ) Share this post Link to post Share on other sites
Eyal Koren 21 Report post Posted December 14, 2014 I'm not sure if this is the sort of suggestion you are looking for on this subject but I'll put it here anyhow. I think it would be great to have some statistical calculation functions. If there was the ability to read a vector/array of values and determine the statistical profile, that would be excellent! The values that would be most helpful I think would be those that are available in Excel when using the statistical analysis tools such are seen here (http://www.real-statistics.com/descriptive-statistics/descriptive-statistics-tools/ ) Please see the attached application. I assembled it according to the "Descriptive Statistics" feature in Microsoft Excel. You may find it useful. Statistics_04_12.ulpr Share this post Link to post Share on other sites
YINGD 1 Report post Posted January 5, 2015 Eyal, Thank you so much for this calculator. Thsi is exactly what I needed! Joe Share this post Link to post Share on other sites
YINGD 1 Report post Posted January 9, 2015 Eyal, I was testing the Statistics program you made and I found a bug that I can't seem to figure out. The Max Value function seems to work fine but when the Minimum Value is less than 0, it sometimes rounds to 0. I tries to narrow down the symptoms and it is somewhat inconsistent. for example: - When I set the range to 2 and I put a 0.1 on the first register and a 5 in the second register, it works but if I reverse the positions so that the 0.1 is in the second register, and 5 is in the first it does not work. - When I set the range to 2 and I put a 0.1 on the first register and a 5 in the second register like the previous example, it works but then if I change the range to 5, it does not work. Attached are a few pictures to show what is happening. Share this post Link to post Share on other sites
Eyal Koren 21 Report post Posted January 18, 2015 Eyal, I was testing the Statistics program you made and I found a bug that I can't seem to figure out. The Max Value function seems to work fine but when the Minimum Value is less than 0, it sometimes rounds to 0. I tries to narrow down the symptoms and it is somewhat inconsistent. for example: - When I set the range to 2 and I put a 0.1 on the first register and a 5 in the second register, it works but if I reverse the positions so that the 0.1 is in the second register, and 5 is in the first it does not work. - When I set the range to 2 and I put a 0.1 on the first register and a 5 in the second register like the previous example, it works but then if I change the range to 5, it does not work. Attached are a few pictures to show what is happening. Thank you for bringing this up! Using your reference I found out that there is a bug in the "Sort Array" function block (which is used to determine min/max values in the application) - apparently It does not sort certain values. I referred it to our R&D department and this bug will be fixed in the upcoming Unilogic version. Thanks again for bringing this up. Share this post Link to post Share on other sites
Eyal Koren 21 Report post Posted January 21, 2015 Eyal, I was testing the Statistics program you made and I found a bug that I can't seem to figure out. The Max Value function seems to work fine but when the Minimum Value is less than 0, it sometimes rounds to 0. I tries to narrow down the symptoms and it is somewhat inconsistent. for example: - When I set the range to 2 and I put a 0.1 on the first register and a 5 in the second register, it works but if I reverse the positions so that the 0.1 is in the second register, and 5 is in the first it does not work. - When I set the range to 2 and I put a 0.1 on the first register and a 5 in the second register like the previous example, it works but then if I change the range to 5, it does not work. Attached are a few pictures to show what is happening. Hi Y.INDS, FYI, the bug in Sort Array function block is fixed, and will be included in the next release of Unilogic (which should be available next month). Share this post Link to post Share on other sites
