greml1n Posted June 26, 2014 Report Share Posted June 26, 2014 Is there a drum configuration in Unilogic. I am trying to convert a program from Visilogic to Unilogic and cant find any drum? Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted June 30, 2014 Report Share Posted June 30, 2014 Hi, Unilogic currently doesn't have a Drum utility. However, I attached an application that has the same functionality. You can add it to your project. UniStream_070_Drum.ulpr 1 Quote Link to comment Share on other sites More sharing options...
greml1n Posted July 20, 2014 Author Report Share Posted July 20, 2014 Ok, so I am plugging away at this drum program and recently noticed that the data table can be accessed/edited in UniApps/Memory/Data Tables. Is there a way to prevent this. I do not want somebody changing the drum sequence. I currently have the table retained in memory Quote Link to comment Share on other sites More sharing options...
hotwires Posted November 26, 2016 Report Share Posted November 26, 2016 I miss the drum sequencer as well! Quote Link to comment Share on other sites More sharing options...
