greml1n Posted August 3, 2014 Report Share Posted August 3, 2014 Hi, #1 - The UniLogic help files refer to linearization for numeric box. Where is that functionality? #2 - Does the linearize under math functions follow the same format as VisiLogic? I could use more explanation of the tag values associated with it. Quote Link to comment Share on other sites More sharing options...
Alexander Posted August 4, 2014 Report Share Posted August 4, 2014 When using multiple input/output function blocks there is a description for each value if you hover the cursor over the respective alphabetical value. This can be used to identify the purpose of each tag within a function block after a tag is created. It does use the same format as VisiLogic. For the linearize function block the values are as follows: A: Input Value (X) B: X1 Value C: Y1 Value D: X2 Value E: Y2 Value F: Result Value (Y) Quote Link to comment Share on other sites More sharing options...
