lluisot Posted August 17, 2014 Report Share Posted August 17, 2014 Hi , i`m need to install a new modem into the modem service,for dial a plc modem (enfora) connected to V130 .This modem is a usb modem gsm/gprs .Specifically a Samba 55 at Falcom Company . http://www.falcom.de/products/discontinued-items/samba5556/. How can i configurate this modem in visilogic modem service ? Thanks from spain Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted August 18, 2014 Report Share Posted August 18, 2014 Hi IIuisot, To be able to configure a modem which is not included in the supported modem list, you should select "other" from the GSM modems list in the "COM Initialize FB". Then you should fill in the specific AT commands of your modem for a successful initialization. Every modem consists on its own sequence and syntax, please follow the product's documentation. Quote Link to comment Share on other sites More sharing options...
lluisot Posted August 18, 2014 Author Report Share Posted August 18, 2014 Hi IIuisot, To be able to configure a modem which is not included in the supported modem list, you should select "other" from the GSM modems list in the "COM Initialize FB". Then you should fill in the specific AT commands of your modem for a successful initialization. Every modem consists on its own sequence and syntax, please follow the product's documentation. Thanks , i need to dial with other modem only .Wath comands i have put ? Quote Link to comment Share on other sites More sharing options...
lluisot Posted August 20, 2014 Author Report Share Posted August 20, 2014 Thanks , i need to dial with other modem only .Wath comands i have put ? Hi , i think this Falcom modem have internally a cinterion modem mc55i . When i initialize pc-side modem , all parameteres are ok , but initialization are not ok. can you help me ? i copy txt log : Communication 20/08/14 09:24:29 Close port Communication 20/08/14 09:24:28 Close port Communication 20/08/14 09:24:26 "Modem Input +CSQ: 99,0OK" Communication 20/08/14 09:24:26 Modem Output AT+CSQ Communication 20/08/14 09:24:23 Modem Output AT+CREG? Communication 20/08/14 09:24:21 Modem Output AT+CREG? Communication 20/08/14 09:24:19 Modem Output AT+CREG? Communication 20/08/14 09:24:16 Modem Output AT+CREG? Communication 20/08/14 09:24:14 Modem Output AT+CREG? Communication 20/08/14 09:24:14 "Modem Input +CSQ: 99,0OK" Communication 20/08/14 09:24:14 Modem Output AT+CSQ Communication 20/08/14 09:24:14 Modem Input CinterionMC55iREVISION 01.201OK Communication 20/08/14 09:24:13 Modem Output ATI Communication 20/08/14 09:24:13 Modem Input OK Communication 20/08/14 09:24:13 Modem Output AT&W0 Communication 20/08/14 09:24:13 "Modem Input ^SCFG: ""Radio/Band/HandOver"",""1""OK" Communication 20/08/14 09:24:13 "Modem Output AT^SCFG=""Radio/Band/HandOver"",1" Communication 20/08/14 09:24:13 Modem Input OK Communication 20/08/14 09:24:12 "Modem Output AT^SGCONF=540,8" Communication 20/08/14 09:24:12 "Modem Input +CPMS: 0,30,0,30,0,30OK" Communication 20/08/14 09:24:12 "Modem Output AT+CPMS=SM,SM,SM" Communication 20/08/14 09:24:09 Modem Input OK Communication 20/08/14 09:24:08 Modem Output ATX4 Communication 20/08/14 09:24:08 Modem Input OK Communication 20/08/14 09:24:08 Modem Output AT&C1&D0&S0Q0S0=0V1 Communication 20/08/14 09:24:08 "Modem Input ^SCFG: ""GPRS/ATS0/withAttach"",""off""OK" Communication 20/08/14 09:24:08 "Modem Output AT^SCFG=""GPRS/ATS0/withAttach"",""off""" Communication 20/08/14 09:24:05 Modem Input ATE0OK Communication 20/08/14 09:24:04 Modem Output ATE0 Communication 20/08/14 09:24:04 Modem Input OK Communication 20/08/14 09:24:04 Modem Output AT&F Communication 20/08/14 09:24:04 Modem Input OK Communication 20/08/14 09:24:04 Modem Output AT Communication 20/08/14 09:24:04 "Open port 7 9600,N,8,1" Communication 20/08/14 09:24:03 Close port Communication 20/08/14 09:24:03 Modem Input OK Communication 20/08/14 09:24:03 Modem Output AT+IPR=9600 Communication 20/08/14 09:24:02 Modem Output AT (BaudRate:9600) Communication 20/08/14 09:24:02 "Open port 7 9600,N,8,1" Communication 20/08/14 09:23:59 Close port Thanks . Quote Link to comment Share on other sites More sharing options...
lluisot Posted August 21, 2014 Author Report Share Posted August 21, 2014 There are a usb modem at list of modems service ? My customer need this option for use in your portable pc. Maybe , the R.D. Team could integrate a modem usb on the modems list . Best regards . Quote Link to comment Share on other sites More sharing options...
lluisot Posted August 25, 2014 Author Report Share Posted August 25, 2014 Nobody ? Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted August 26, 2014 Report Share Posted August 26, 2014 There are a usb modem at list of modems service ? My customer need this option for use in your portable pc. Maybe , the R.D. Team could integrate a modem usb on the modems list . Best regards . Hi IIuisot, USB modems can not be supported for Vision PLC's, basically because of lack of a USB host port. Quote Link to comment Share on other sites More sharing options...
lluisot Posted August 26, 2014 Author Report Share Posted August 26, 2014 Hi IIuisot, USB modems can not be supported for Vision PLC's, basically because of lack of a USB host port. Hi Eyal , i`m not need a usb modem for plc . Only for a PC . Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted August 26, 2014 Report Share Posted August 26, 2014 Hi Eyal , i`m not need a usb modem for plc . Only for a PC . I don't exactly understand what you mean. Could you please explain the system architecture? Quote Link to comment Share on other sites More sharing options...
lluisot Posted August 26, 2014 Author Report Share Posted August 26, 2014 I don't exactly understand what you mean. Could you please explain the system architecture? OK Eyan .Is this: In the side PLC, i have a V130 whih a 1308 Enfora Modem (GSM /GPRS) connected in the second RS232 port. In the side PC i want a USB Modem ( GSM /GPRS). I send SMS from PLC , and i need conect visilogic to V130 whith a phone call. Thanks Quote Link to comment Share on other sites More sharing options...
