lluisot Posted August 25, 2014 Report Share Posted August 25, 2014 Hi , is possible this ? Sometimes i need to force a digital input . Quote Link to comment Share on other sites More sharing options...
dan Posted August 25, 2014 Report Share Posted August 25, 2014 Hi, A digital input can be forced from the VisiLogic software and using the info mode of the controller. Visilogic- Go into online test. Double click on the input you would like to force. Right click and the click "force to 1". Info mode- Enter info mode of the controller. Select the operands > Inputs. Select the input you would like force and click F1 at the bottom of the screen. Please note that you must clear the force when done. Dan Quote Link to comment Share on other sites More sharing options...
lluisot Posted August 25, 2014 Author Report Share Posted August 25, 2014 Hi, A digital input can be forced from the VisiLogic software and using the info mode of the controller. Visilogic- Go into online test. Double click on the input you would like to force. Right click and the click "force to 1". Info mode- Enter info mode of the controller. Select the operands > Inputs. Select the input you would like force and click F1 at the bottom of the screen. Please note that you must clear the force when done. Dan Thank you . I tested and it's ok Lluisot Quote Link to comment Share on other sites More sharing options...
