cbryan Posted September 15, 2014 Report Share Posted September 15, 2014 I have more than 20 units out in the field and producing more every day. They have been floating around for 1-2 years all with nearly identical programming. I recently had to swap out a unit for a customer because they turned on the V560 and saw nothing but red. Its the factory boot screen, only it looks broken. In an effort to keep things the same for over the phone troubleshooting I had only updated my visilogic program once and that was to 9.5.0. Due to the model number on this unit I know that 9.5.0 was used when the program and O/S were downloaded into the PLC. In an attempt to fix I first tried Boot Strap. Every combination of doing so has failed. ( Touch the screen then turn on or press and hold i and turn on ) It does nothing with exception of on occasion look more messed up. I did this with the CanBus removed and I also removed the snap-in I/O board ( V200-18-E2XB but I doubt this has any role in the problem ) I was hoping to find a way without connecting to a PC so in the event it ever happened again I would know what to tell a customer over the phone. After a frustrating 20 Min and another 2 hrs looking for a solution online here I am. I can see the PLC I can get the O/S information: O/S : 3.8(02) BOOT: 2.2(09) BinLib: 1-1.10(01) Factory Boot: 1.3 (07) Every which way I try it the O/S update fails. I even did update Visilogic to 9.7.9 with no change. I attempted to update the O/S at this point but failed. I then did them one at a time starting with Bin Lib then Boot then O/S. Again Fail at the O/S installation. The unit is currently sitting at : O/S : 3.8(02) BOOT: 2.2(19) BinLib: 1-1.10(01) Factory Boot: 1.3 (07) Running Win8 with a prolific USB-Serial ( my preferred way ) However I have also tried with Vista Pro Downgraded to XP with an integrated serial port with no change. ( I did not however update visilogic on it ) I will be more than happy to supply any information I may have left out ( its me so likely a lot ) Please help. Thank you. Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted October 2, 2014 Report Share Posted October 2, 2014 Hi cbryan, In general, the method for installing the OS to the PLC is the correct way to fix this issue. A sanity check - Are you connected to the PLC via port1? You can update the OS from this port only. Quote Link to comment Share on other sites More sharing options...
cbryan Posted October 2, 2014 Author Report Share Posted October 2, 2014 Thank you for the reply. Yes port1. Always. Quote Link to comment Share on other sites More sharing options...
