MVP 2023 Flex727 Posted September 25, 2014 MVP 2023 Report Share Posted September 25, 2014 According to the message at the bottom of this page, I can only post an attachment with a max file size of 229 bytes. Why is this? Obviously it is not possible to post any useful attachment with only 229 bytes. Is the problem on my end? What settings should I be looking at? I am running Win 7 - 64 bit and using Chrome. Quote Link to comment Share on other sites More sharing options...
Michael_P Posted September 25, 2014 Report Share Posted September 25, 2014 Hi Flex, If posting an application to the forum you will want to use the navigation plane at the top of the forum that is labeled downloads. This will allow you to upload your file to be available for download by other users of the forum. This is what i do when i post a file. Thanks Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted September 25, 2014 Author MVP 2023 Report Share Posted September 25, 2014 Thanks, but I'm not wanting to post an application to share right now, but instead want to post a graphic that shows an error message. Quote Link to comment Share on other sites More sharing options...
Michael_P Posted September 25, 2014 Report Share Posted September 25, 2014 Hi Flex, If you want to post an image then you should navigate to the gallery and use the upload option in the gallery. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted September 25, 2014 Author MVP 2023 Report Share Posted September 25, 2014 When I do that it says: Sorry, you don't have permission for that! Quote Link to comment Share on other sites More sharing options...
Michael_P Posted September 25, 2014 Report Share Posted September 25, 2014 Hi Flex, I do not think I have the ability to change specific settings, but from what i can find there is no reason you should be getting blocked from uploading an image. I have had no trouble so it is not a site condition. It seems to be specific, we will need to dig deeper to determine the condition. Quote Link to comment Share on other sites More sharing options...
sgull Posted September 25, 2014 Report Share Posted September 25, 2014 Hi Flex I think this happened to me before. If you go to your profile page and then to settings. There should be a tab called "manage attachments" Here you can delete old files that may be taking up space. Regards Denis 1 Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted September 25, 2014 Author MVP 2023 Report Share Posted September 25, 2014 That seems to have solved my problem. Thanks, sgull! Quote Link to comment Share on other sites More sharing options...
