Straker Posted September 26, 2014 Report Share Posted September 26, 2014 I need to use the ActiveX in order to update a very old VB6 program. I downloaded the file from Unitronics's download section In description you can read: ActiveX Communication DriverThis zip file contains an ActiveX .dll file that can be used to implement SCADA. UnCmDrv1.dll file contains methods and properties for invoking the PLC, read / write, locally or remotely, implementation examples, and an explanation of accessing Data Tables. But when I unzipped the rar package only the UnCmDrv1.dll (434kb) was present. I need some more explanations and examples about how to use the dll... Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted September 30, 2014 Report Share Posted September 30, 2014 Hello, here is the link for more information and examples: http://www.unitronics.com/docs/technical-library/examples.zip?sfvrsn=0 Cheers Quote Link to comment Share on other sites More sharing options...
