cantcliff Posted October 3, 2014 Report Share Posted October 3, 2014 Is it possible to dynamically change the drum step time through user input? For example, link it to an MI so that the time is adjustable based on recipe, or would I need to use a 0 time step and a timer to control moving to the next step? Quote Link to comment Share on other sites More sharing options...
s.pratt Posted October 3, 2014 Report Share Posted October 3, 2014 Hello, Thank you for using our Unitronics Forum. Unfortunately, the time duration in the drum sequencer configuration is not indirect. You could create different configurations according to when recipe, the have the user just choose the recipe they are running to run the according drum. The other option is as you stated above: use a timer entered by the operator to run the next step functions blocks. Quote Link to comment Share on other sites More sharing options...
AlexUT Posted February 25, 2015 Report Share Posted February 25, 2015 You can define 00:00:00.00 time in DRUM, then use separate timer values for each DRUM step from Data Table. Data Table will include sets of timers and other parameters for DRUM. When timer ends - issue command "Go to next step" and DRUM will shange state. This way you can use recipies. 1 Quote Link to comment Share on other sites More sharing options...
Voxdale Posted October 27, 2021 Report Share Posted October 27, 2021 Hello, So the values in the Data Table are then timers which can be adjusted on the display by the operator? Is it possible to give an example of how you make the link to this Data table? Quote Link to comment Share on other sites More sharing options...
stembera Posted October 28, 2021 Report Share Posted October 28, 2021 I do this task this way: Put every step timer in Drum configuration to 00:00:00 and set an external timer to every step. User can change the timer preset to desired value easily from display. Quote Link to comment Share on other sites More sharing options...
