Edwin Posted November 24, 2014 Report Share Posted November 24, 2014 Hello, Currently I'm using the MODBUS RTU to DMX converter from t-mac in the UK. But some DMX drivers cannot get the correct data from the converter. Is there another way to control a DMX driver with a V350? This may be done with an interface (CANBUS/MODBUS IP to DMX) or directly from the PLC. Thanks in advance, Greets Edwin Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted December 2, 2014 Report Share Posted December 2, 2014 Hi Edwin, Unfortunately it is not possible to communicate with DMX 512 devices using our Vision controllers. The DMX 512 protocol communications baud rate is 250 Kbaud, which is not supported by Unitronics PLC's. Quote Link to comment Share on other sites More sharing options...
