dtwbb Posted December 4, 2014 Report Share Posted December 4, 2014 Hi I'm making program for measuring temperature from 1200C to 1600C. The program is saving data in SD trend with play-pause (append). My latest problem is that when I open SD Trend I see the oldest recording. Is there any system solution for previewing the newest data, the last recording. Thank you Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted December 22, 2014 Report Share Posted December 22, 2014 Hi dtwbb, Thank you for this post. Currently, Visilogic does not have a feature for automatically landing on the most current trend data. I will make a suggestion to our R&D department to find a solution for your request. Quote Link to comment Share on other sites More sharing options...
dtwbb Posted January 16, 2020 Author Report Share Posted January 16, 2020 Hi there Is there any solution for the problem I see others on the forum have the same problem ??? Quote Link to comment Share on other sites More sharing options...
