Fabios Posted December 16, 2014 Report Share Posted December 16, 2014 Hi, I have installed already Unilogic 1.7 Rev62. If I launch setup of the new 1_9 build 19, appears this window: What can I do? (window7 64 bit) Best Regards Fabio Quote Link to comment Share on other sites More sharing options...
Fabios Posted December 16, 2014 Author Report Share Posted December 16, 2014 solved! Thank you. Quote Link to comment Share on other sites More sharing options...
Saragani Posted December 17, 2014 Report Share Posted December 17, 2014 Solved how? Share your solution so others might benefit from it. Thanks. Quote Link to comment Share on other sites More sharing options...
lawry Posted December 17, 2014 Report Share Posted December 17, 2014 ??? Quote Link to comment Share on other sites More sharing options...
Fabios Posted December 17, 2014 Author Report Share Posted December 17, 2014 Solved how? Share your solution so others might benefit from it. Thanks. Of course! Simply performed manual disinstallation the previous version and only then start the new installation! Other time this operation was automatic. BR Fabio 1 Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted December 18, 2014 Report Share Posted December 18, 2014 Fabio, thanks for posting that solution :-) Quote Link to comment Share on other sites More sharing options...
