small7
Problem with V1210 - PLC goes to stop mode
Hello
At the end of January i changed program in PLC (I have few lines in one Net - last ldr error). It seemed that it will be ok (earlier plc work about 2 weeks now it's work 7 weeks), but today PLC stop and i have new error code.
Awaria Plc 2
This Ldr error code  follow to
Program
What is wrong in this nets?
The Ldr code will direct you to the subroutine that is causing the issues. If possible please send the project along with as many details as possible to support@unitronics.com for further review.
ldr error direct to nets in image 2.
There does not appear to be anything wrong with the code in the image that you posted.
Has this issue occurred again? If the issue is repeatable please send your program in for further review to support@unitronics.com
If we are able to replicate this issue consistently we may be able to determine the issue that caused it. Often this type of error occurs when a very specific sequence of events occurs within the PLC. Please let us know the exact conditions of any I/O or settings within the controller that led up to this error being displayed.
"No Application" means there is no software in the PLC for it to run. Was the battery removed? If not,  it may have failed.  How old is the PLC? The battery typically lasts about 10 years. You will need to find the original .vlp file or a file that was saved to an SD card.
Thanks for the reply
What i should do now ..sir?
Where i can find vlp file.
I have nothing here ...
Ramzan63@gmail.com
The .vlp file is created by Visilogic software and is the PLC program.
If you are not the original creator of the program you will need to get a copy of it.  Visilogic can be downloaded from this website and you can load the .vlp file into the PLC with it.
If you do not have or can not get the .vlp file then you are dead in the water.
Hi,
I used PLC V280-18-B20, OS 3.75 After update os to v5.02 PLC stop mode screen displayed and not running.please help me solve this issue and revert back to install  previous os.
Do not make OS and any other update to old PLC hardware.
You have to use the same VisiLogic version you used last time.
Roll-back to OS 3.75 and to old VisiLogic.
Hope PLC will work.
B.R.
Hope PLC will work.
B.R.
Hi,
Thank you for the reply I checked in website only VisiLogic  v7.1 available .I tried but I cant able to roll back .please help me to revert back os to 3.7.
Thanks
cherian
Please send your request to support@unitronics.com
Add PLC serial number and exact model number to your request.
B.R.
B.R.
Hi
Thank you for the update
I already registered ticket and now I sent the mail to the support.
thanks
ckc
