Innov Posted December 21, 2010 Report Share Posted December 21, 2010 Hi, Just wondering if anyone can help I'm using a V350 with TRA22 expansion. I'm trying to use the date as a file name for saving a CSV excel file? Currently I use the RTC (dd/mm/yy) to ASCII and save the result in an ML and try to use this as an indirect input into the delimited line but this gives status error 2: Fail to Open File. I think its to do with the "/" that gets stored in the ASCII number, as i tried experimenting with this using constant text and got the same error status. I'm wondering if there is a work around for this? I think i can use either vectors to fill in the date using the relevant SI bits(32 and 33) but im not sure how to fill up the vector correctly? Or I could use the String Remove function to remove the "/" from the RTC to ASCII conversion but again i'm not sure how to do this correctly? Hoping someone can point me in the right direction Cheers, Innov Quote Link to comment Share on other sites More sharing options...
Innov Posted December 22, 2010 Author Report Share Posted December 22, 2010 Hi, Came up with a workaround I just multiplied the SI 32 (DDMM) by 10000 then adding in SI33 (YYYY) and performed a NUM to ASCII conversion and this gave the date that can be stored as a filename. Might help someone in the future Cheers, Innov Quote Link to comment Share on other sites More sharing options...
Sabastian Posted March 12, 2020 Report Share Posted March 12, 2020 El 22/12/2010 a las 3:48, Innov dijo: hola Innov. me podrias ayudar con un ejemplo Gracias.. Quote Link to comment Share on other sites More sharing options...
