denogoro Posted January 10, 2015 Report Share Posted January 10, 2015 Hi, I'm interested in how they can connect Linear magnetic scale (5VDC output) on the V280, Snap module v200-18-E6B? If you can not connect. Is there a model that can be.? BR Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted January 13, 2015 Report Share Posted January 13, 2015 Hi denogoro, Unitronics, as most PLC manufacturers, is compatible with industrial devices that consist of 24V or 12V voltage. It is technically possible to use 5VDC devices using external electronic converters, but doing so is not recommended. Quote Link to comment Share on other sites More sharing options...
