RickM Posted August 5, 2010 Report Share Posted August 5, 2010 I have 11 units emailing me an attached csv file every 15 minutes, one of the units is erroring with a status message of "521". All of the units are operating with O/S 3.1 build 05 and programmed with Visilogic 8.6. Is there a complete listing of the error codes for the email function? 1 Quote Link to comment Share on other sites More sharing options...
Ofir Posted August 5, 2010 Report Share Posted August 5, 2010 Hi RickM, Status 521 means that the path of the file is not found. This can be caused by wrong folder or wrong file name in Email function - Please verify. Does the same application run on all units? We will take care to update the Error list in the help file. Sorry for the inconvinience. Quote Link to comment Share on other sites More sharing options...
RickM Posted August 5, 2010 Author Report Share Posted August 5, 2010 Ofir Thanks for the prompt reply. The same application is running on all units. I was able to connect to the mobile unit and it looks like it may be a SD Card problem, I have not received a email since last night and the SD card is now showing not present SB217 off). Will have to chase down the unit. Rick Quote Link to comment Share on other sites More sharing options...
