RenevdBrink
Export Trend File to CSV
Hello,
(Unistream PLC and 10.4 Inch screen)
I Try to export the trend data from a Datasampler to a CSV (EXEL) File
I get it from the SD-card with filezilla.
Sometimes the file will be generated and sometimes it won't
I stop the data sampling and then i set the create CSV bit.
in ladder function.
But it not always generate the file (.ZIP)
Is there an example how this file must be generated.
I use Unilogic version 1.9 rev 19
I have tried a full download and so on but sometimes it works sometimes it won't
Is there any example how this works.
 Thanks René
Hi Rene,
Please see the attached project.
In the Data Sampler1 struct there is a "Create CSV" bit. When this bit is turned on, every time you will stop the sampling or when the sampler reaches the maximum samples (60000 samples) a new CSV will be written to the SD card.
Please let me know if that works for you.
UniStream_070_Data_Sampling_And_Trend.ulpr
On 2/8/2015 at 9:16 AM, Eyal Koren said:
Hi Rene,
UniStream_070_Data_Sampling_And_Trend.ulprUnavailable
Hello Eyal,
Can I see the attached project named "UniStream_070_Data_Sampling_And_Trend.ulpr? I have a same problem.
Thanks.
