guilherme_pires Posted February 20, 2015 Report Share Posted February 20, 2015 hi , I installed VisiLogic 7.9.47 on my computer, but when I try to run the program the following message appears : Run -Time error 32811 Application-defined or object -defined error. I tried to uninstall and delete all folders and install again , but the problem continues. How can I fix this problem ? Quote Link to comment Share on other sites More sharing options...
AlexUT Posted February 22, 2015 Report Share Posted February 22, 2015 Hi, Right-click on VisiLogic installation file, select "Properties" and Unblock it. Then run installation. *Your PC account should have an administrative rights. If not - run installation file as administrator. It will first uninstall previously installed version. Run installation file as administrator again and finish installation. Run VisiLogic as Administrator if needs. I hope this fix error message. B.R. Quote Link to comment Share on other sites More sharing options...
Martin Holaň Posted November 2, 2016 Report Share Posted November 2, 2016 To AlexUT. your advice not working. it doesnt have nothing to do with administration, its about runtime library which is corrupt or missing in pc. I try many way how to resolve this issue but still i have this problem. Propably only solution is reinstal OS. Quote Link to comment Share on other sites More sharing options...
