Exouxas Posted February 26, 2015 Report Share Posted February 26, 2015 Hello, I've got a sreen filled with Numeric Boxes that make up a table to use for parameters. I noticed that you have "$_title" in the Keyboard Title, and you can set your own title, but is it possible to make this title variable? The columns are shifted from side to side depending on a variable, and I'd like to add a text that says something like "Column %Column_Number%, Rotation Speed" If you're wondering how the columns are set up: 4 On-Screen Columns 17 On-Screen Rows 20 Off-screen Columns 17 Off-screen Rows Thanks, Exouxas Quote Link to comment Share on other sites More sharing options...
Saragani Posted February 26, 2015 Report Share Posted February 26, 2015 No, that's not possible. The main purpose of the $_title is that it represents the default title of the variable. For example, it numeric, it is Min-Max, so you can change it to: Please enter a temperature in range $_title And if you add another language to the project, then you can translate it and write for example: Se il vous plaît entrer une température dans la gamme $ _title Quote Link to comment Share on other sites More sharing options...
