Mare Posted February 28, 2015 Report Share Posted February 28, 2015 Hello, How to make to be one box (ASCII String) for several names. Example I need to write in that box Marc as user 1,David as user 2… Now I need to save each user in own line to String Library. Quote Link to comment Share on other sites More sharing options...
EduMarg Posted March 1, 2015 Report Share Posted March 1, 2015 Hi Marko, I send you an e-mail with the answer to this. This is not possible using string library. You will need to use Data tables. Save the user names on the data table. You will read the name from the DT and save it to an array of MI, then link this array to a ascii string variable on the screen and use the touch property to link to the MB you wish use to activated an action. regards Quote Link to comment Share on other sites More sharing options...
