Hello,
have an application in which I have to enter string in a form for example "222-333"...
Due "minus" sign in the string customer has to move between two offered keypads, one containing numbers/letters and one containing "-" sign.
I wonder if there is possibility to make "custom" keypad which would contain both digits and "-" sign on same layout?
It would be even more convinient if keyboard could only contain digits and "-"sign because customer would use only numbers and "dash". Simple numeric keypad looks exactly like one I need but it could be used only for numeric input and "-" sign on it can't be used as "dash" between digits.
So, what can be done to easy a life for customers need to input string variable in above mentioned format on v570?
Thank you
Regards
Marko Kocijan
LOGOKOD
Croatia
