External Moderators tmoulder Posted January 7, 2011 External Moderators Report Share Posted January 7, 2011 Hi All, Vision 280, latest OS and Visilogic 863. I'm using a data table for process parameters. All DT commands are manually triggered from the touchscreen. When I try to read from the DT, sometimes the read takes place, sometimes not. I've got an indicator on-screen that shows the net executing the DT Read has operated, but not data was read. Repeated presses of the touchscreen button will eventually make the read happen. Very bizarre. I could work around it with a latching arrangement, but I'd rather find a root cause. One thing I did differently in this application was grouping multiple data elements into single columns (Column 1 has three elements, A, B, C, all signed integers). I'm wondering if there is a relationship. Thanks, TM Quote Link to comment Share on other sites More sharing options...
Deke Posted January 8, 2011 Report Share Posted January 8, 2011 Hi Tim, I use the V280 as well, I'm not at the same OS yet, but I currently read from the DT with multiple items (51) in a single column with no problem, all within a sinlge scan no latching involved. Maybe I'll wait to see how this pans out before I update the OS on them. Thanks, Deke Quote Link to comment Share on other sites More sharing options...
dahnuguy Posted January 23, 2011 Report Share Posted January 23, 2011 Hi All, Vision 280, latest OS and Visilogic 863. I'm using a data table for process parameters. All DT commands are manually triggered from the touchscreen. When I try to read from the DT, sometimes the read takes place, sometimes not. I've got an indicator on-screen that shows the net executing the DT Read has operated, but not data was read. Repeated presses of the touchscreen button will eventually make the read happen. Very bizarre. I could work around it with a latching arrangement, but I'd rather find a root cause. One thing I did differently in this application was grouping multiple data elements into single columns (Column 1 has three elements, A, B, C, all signed integers). I'm wondering if there is a relationship. Thanks, TM The screen acts like a pulsed input or positive transition. DTs don't like that. Quote Link to comment Share on other sites More sharing options...
Emil Posted January 23, 2011 Report Share Posted January 23, 2011 Can we receive the demo to simulate the problem? We really need it! Quote Link to comment Share on other sites More sharing options...
