jordy55 Posted May 5, 2015 Report Share Posted May 5, 2015 Hello everybody, I've got a question about Unitronics with CANopen. I am doing an internship and have my own project here. It's a Foil test installation with an extruder. Now I have 2 servo controllers (CDE3004) and I want them to communicate with my Unitronics V1040. But I have a little bit trouble understanding the CANopen configuration. The idea is that I can read the parameters from the servo controllers. For instance the RPM, Torque, Power and Errors/Warnings. And that I can control them from 0 to 100% I also found some information concerning the servo controllers; Info about Servo Controllers CAN here are in my opinion the values for CANopen? Or am I wrong with this. maybe someone can give me a push in the right direction with how to set the configuration. (Sorry for my english if it's not quite right) Quote Link to comment Share on other sites More sharing options...
silikon Posted May 5, 2015 Report Share Posted May 5, 2015 Sorry for my poor English 'google helps me. I think you'll understand me: Unitronic no solution for your problem. Unitronic does not support CANopen protocol CiA DS402 , CiA DS301 only. Read about the differences, there are plenty on the internet. Good luck Quote Link to comment Share on other sites More sharing options...
jordy55 Posted May 18, 2015 Author Report Share Posted May 18, 2015 So you're saying that I can not control the servo controller with CANopen? The seller said that this was possible. Quote Link to comment Share on other sites More sharing options...
cantcliff Posted May 18, 2015 Report Share Posted May 18, 2015 The V1040 does support CANopen according to the unitronics webpage. Under the support section there is a manual for communications, page 119 of the pdf (113 of the manual) talks about using the CANopen functions blocks. Quote Link to comment Share on other sites More sharing options...
