Sohel Posted May 7, 2015 Report Share Posted May 7, 2015 Hi All, What is UniVision Licensing?? Would You Please explain the working of UniVision Licensing. please also suggest the Pros of Univison Licensing in comparison with other PLC software. Best Regards Sohel Quote Link to comment Share on other sites More sharing options...
Alexander Posted May 11, 2015 Report Share Posted May 11, 2015 Our Licencing utility allows three separate data keys to be burned into a single PLC's memory. These codes can then be used to enable logic or HMI displays within the PLC, disable the ladder after a certain period of time has expired. This benefits the programmer though utilizing the three data keys for licensing for an individual PLC's one at a time, instead of only using a program which would operate in all identical models of controllers without restriction. For further information I would recommend watching our webinar on this feature. http://www.unitronics.com/support/webinars/license 1 Quote Link to comment Share on other sites More sharing options...
Sohel Posted May 14, 2015 Author Report Share Posted May 14, 2015 Dear Alex Thank You so much for Your Valuable response. I have an application in which Circular interpolation is required. We have a PTO facility in Unitronics. But Do we have Interpolation feature in Unitronics?? Please kindly provide some useful OPLC solution on this. Best Regards Sohel Quote Link to comment Share on other sites More sharing options...
Alexander Posted May 14, 2015 Report Share Posted May 14, 2015 Can you further elaborate on what type of application you need, and how it relates to circular interpolation? There are direct linearization functions, though there are not any specifically for circular interpolation. Quote Link to comment Share on other sites More sharing options...
