russedwards Posted May 7, 2015 Report Share Posted May 7, 2015 HI I have a problem that I cannot get to the bottom of. When writing a DT to an SD card, i can get the data to transfer without a problem. Now, when I remove the SD card to transfer the data to the PC, and then re-insert the card to the V350 and try and transfer another DT, the transfer freezes and will not restart until i perform a Reset of the PLC. Does anyone have any ideas? Quote Link to comment Share on other sites More sharing options...
Walkerok Posted May 10, 2015 Report Share Posted May 10, 2015 Without posting your program for someone to see either here on the forum or directly to Unitronics support I don't think anyone is going to be able to help you with a solution to your peoblem. Keith Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted May 11, 2015 MVP 2023 Report Share Posted May 11, 2015 Are you putting the SD card directly into the PLC, or are you using an extension of some sort? Quote Link to comment Share on other sites More sharing options...
