JardaK Posted May 12, 2015 Report Share Posted May 12, 2015 How can I solve this problem? USP-070-B10 USC-P-B10 unistream firware upgrade your firmware is up to date no upgrade is need invalid user application the controller does not contain a valid application. this may be due to a corrupted application or version mismatch check that you are using the most recent unilogic software and unistream firware version, verify com settings perform download all if problem repeats, please contact support Quote Link to comment Share on other sites More sharing options...
Alexander Posted May 13, 2015 Report Share Posted May 13, 2015 I would try to download a blank project to the controller, then re-download your project. If the project has become corrupted then this should clear out any previous issues. Quote Link to comment Share on other sites More sharing options...
Saragani Posted May 21, 2015 Report Share Posted May 21, 2015 A download All would also re-download the project Quote Link to comment Share on other sites More sharing options...
JardaK Posted May 26, 2015 Author Report Share Posted May 26, 2015 Thank you for the advice Quote Link to comment Share on other sites More sharing options...
