Stavros Posted June 2, 2015 Report Share Posted June 2, 2015 Hello, I have one M91-2-UA2 PLC programmed for one analog input and one analog output. My analog input settings is between MI0 - MI20 and my analog output settings is above MI20. I downloaded my program in the PLC and check it on line by changing the values of my MI's and everything was working fine. I switched OFF my power supply because i wanted to give 24v DC to output terminals to measure the analog output and then I switch it ON, when I get on line I realized that the values above MI15 was not be saved and all of them was 0 (MI0 - MI15 was ok). I saved new values on MI15 to MI100 and switched OFF and then ON my power supply, the problem is the same , zero values from MI15 and above. I test my PLC like that for 3 times. I updated my PLC version to 3.90 biould 03 and the probem is still there.I mesaure the battery and the voltage is 3.06 V DC. Do you know anything about my problem ? Any ideas or sugestions are welcome. Thank you in advance. Best reqards Stavros Quote Link to comment Share on other sites More sharing options...
Michael_P Posted June 2, 2015 Report Share Posted June 2, 2015 Hi Stavros, It may help to ensure there are no power-up values assigned. Another key is to check to see if the RTC (real time clock) has been reset. If this is the case and it is resetting you may wish to contact Support@Unitronics.com for further assistance. Quote Link to comment Share on other sites More sharing options...
lawry Posted June 3, 2015 Report Share Posted June 3, 2015 In the download section, uncheck "Initialise Data Types excluding MI & MB 0 - 15 (M90) style" and check "Retain Values (Battery Back up" Lawry Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted June 4, 2015 Report Share Posted June 4, 2015 Check on help files, searching battery back-up. There´s a topic explaining this behavior Quote Link to comment Share on other sites More sharing options...
