External Moderators tmoulder Posted January 10, 2011 External Moderators Report Share Posted January 10, 2011 Hi guys, There seems to be a bug in the background images. If I put in a new image and choose to replace all occurences (same background in several screens) and cycle power, the power-up display has a black and white background with hebrew text on it. Changing screens after this results in each screen piling on top of the next, with no update to the background for any of them. If I change the background images individually, no problems Thanks, TM Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted January 10, 2011 Report Share Posted January 10, 2011 Hi, I just check it with 4 displays and it's ok. Can you tell me how many displays are you using? Try to download VisiLogic V9.0.1 from our web site which we upload it today and try again. Can you attache your project? 10x Quote Link to comment Share on other sites More sharing options...
External Moderators tmoulder Posted January 10, 2011 Author External Moderators Report Share Posted January 10, 2011 Hi R.Mozes, Only 4 displays, downloaded Visilogic brand new this morning. I can't post the project publicly, so I'll email it to you at support. Thanks, TM Quote Link to comment Share on other sites More sharing options...
bdanders Posted March 11, 2011 Report Share Posted March 11, 2011 I may be experiencing a similar issue. I tried to change all occurences of a binary image on a V570, but after changing it the image no longer appears on the screen and each screen that has an image is unresponsive. I have tried removing all of the images and the screens will work, but if I try to add any images back to the screens, they freeze again. Quote Link to comment Share on other sites More sharing options...
selfbuilding Posted June 20, 2011 Report Share Posted June 20, 2011 Here the same problem that also has "bdanders", the entire screen with a new image hangs the OPLC, when the image is removed everything is back to normal. But with that, all projects are stopped until the problem clears. The problem occurs in V570 with new OS and visilogic 9.3.0. Quote Link to comment Share on other sites More sharing options...
