Gugulanov Posted July 15, 2015 Report Share Posted July 15, 2015 Hello, I'm testing the e-mail option in Unilogic, but I'm having troubles with it. DNS servers are OK. Account settings are OK. (I used a network sniffer to see that the plc connect to domain server, and then to mail server) Status code in e-mail struct is -5 , which is "Access denied". Settings for account are so few, that I'm starting to think that this is connected somehow with SSL. So my question is - does the e-mail option use SSL in SMTP protocol? Regards, Gugulanov Quote Link to comment Share on other sites More sharing options...
s.pratt Posted July 15, 2015 Report Share Posted July 15, 2015 Hello Gugulanov, The e-mailing feature in the UniStream does support SSL encrypted e-mails. Are you sure your username and password are correct? Are you able to log on to your mail server using this username and password? Quote Link to comment Share on other sites More sharing options...
Gugulanov Posted July 15, 2015 Author Report Share Posted July 15, 2015 Hi, thanks for the quick reply. Okay, I'll check again everything.... Tomorrow I will answer with more info.... Regards Quote Link to comment Share on other sites More sharing options...
Gugulanov Posted July 16, 2015 Author Report Share Posted July 16, 2015 Hi, So, the things are OK now, the problem was in the field "From E-mail address" in account settings.This field is missing in "Help" files and in the tutorial video for e-mail sending. The e-mail feature works with this field - blanc, or with same text as "Username". In my case, I had this field filled with random address and after sending, the status of sending was -5. Regards Quote Link to comment Share on other sites More sharing options...
