Error: Cannot Complete Action (163)
Hello! I recently tried to open my project in VisiLogic and got the following error:
You cannot complete this action because:
-there is not disk in the drive, or
-the disk in the drive is full, or
-the disk in the drive is write-protected.,
I haven't changed anything in my computer (running Windows 7). Has anyone else encountered this problem and/or have suggestions?
Thanks!
  • 2 years later...
  • 3 months later...
  • MVP 2023
6 hours ago, serebral said:
Hello, my problem is same
I've had a look at your program and it is completely full of Nulls.  Something has gone wrong somewhere.  Hopefully you have a previously saved version you can go back to.  For this reason don't keep on saving progressive program builds (or anything, for that matter) under the same name.  At the very least, alter them so that you have a rotating series of names that you work with on a FIFO basis.
cheers,
Aus
  • 1 month later...
cheers,
Aus
thanks for your interest
  • 2 years later...
