wpreiss Posted August 2, 2015 Report Share Posted August 2, 2015 Hi, I have a data table file paramete.udt which was saved by a V350 to an SD card. I need to externally edit this table, and write it back to the V350. Exporting works perfectly, I also can open the file in the Data Tables Editor. However if I try to change a value, the software crashes. (I am trying to change a value from 20 to 5. The Table is not part of the project, nor write-only. The value to be set is within min/max values. I have installed the most recent sd card suite, and it happens on different windows 7 machines Is there a work around except writing an table editor within the V350? Following the Details: Informationen über das Aufrufen von JIT-Debuggenanstelle dieses Dialogfelds finden Sie am Ende dieser Meldung.************** Ausnahmetext **************System.ArgumentOutOfRangeException: 'col' must be non-negative and less than the number of columns in tableParametername: col bei Unitronics.DataTables.Cells.checkColIndexValidify(Int32 col, String name) bei Unitronics.DataTables.Columns.Column.get_Cells() bei Unitronics_Data_Tables_Editor.EditCellView.setValuesToTable() bei Unitronics_Data_Tables_Editor.EditCellView.btnOK_Click(Object sender, EventArgs e) bei System.Windows.Forms.Control.OnClick(EventArgs e) bei System.Windows.Forms.Button.OnClick(EventArgs e) bei System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) bei System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) bei System.Windows.Forms.Control.WndProc(Message& m) bei System.Windows.Forms.ButtonBase.WndProc(Message& m) bei System.Windows.Forms.Button.WndProc(Message& m) bei System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) bei System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)************** Geladene Assemblys **************mscorlib Assembly-Version: 2.0.0.0. Win32-Version: 2.0.50727.5485 (Win7SP1GDR.050727-5400). CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll.----------------------------------------Unitronics Data Tables Editor Assembly-Version: 1.0.19.0. Win32-Version: 1.0.19.0. CodeBase: file:///C:/Program%20Files%20(x86)/Unitronics/SD%20Card%20Suite/Unitronics%20Data%20Tables%20Editor.exe.----------------------------------------System.Windows.Forms Assembly-Version: 2.0.0.0. Win32-Version: 2.0.50727.5491 (Win7SP1GDR.050727-5400). CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll.----------------------------------------System Assembly-Version: 2.0.0.0. Win32-Version: 2.0.50727.5485 (Win7SP1GDR.050727-5400). CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll.----------------------------------------System.Drawing Assembly-Version: 2.0.0.0. Win32-Version: 2.0.50727.5491 (Win7SP1GDR.050727-5400). CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll.----------------------------------------Infragistics2.Win.UltraWinGrid.v9.2 Assembly-Version: 9.2.20092.2119. Win32-Version: 9.2.20092.2119. CodeBase: file:///C:/Program%20Files%20(x86)/Unitronics/SD%20Card%20Suite/Libraries/Infragistics2.Win.UltraWinGrid.v9.2.DLL.----------------------------------------Infragistics2.Win.v9.2 Assembly-Version: 9.2.20092.2119. Win32-Version: 9.2.20092.2119. CodeBase: file:///C:/Program%20Files%20(x86)/Unitronics/SD%20Card%20Suite/Libraries/Infragistics2.Win.v9.2.DLL.----------------------------------------Infragistics2.Shared.v9.2 Assembly-Version: 9.2.20092.2119. Win32-Version: 9.2.20092.2119. CodeBase: file:///C:/Program%20Files%20(x86)/Unitronics/SD%20Card%20Suite/Libraries/Infragistics2.Shared.v9.2.DLL.----------------------------------------Infragistics2.Win.UltraWinToolbars.v9.2 Assembly-Version: 9.2.20092.2119. Win32-Version: 9.2.20092.2119. CodeBase: file:///C:/Program%20Files%20(x86)/Unitronics/SD%20Card%20Suite/Libraries/Infragistics2.Win.UltraWinToolbars.v9.2.DLL.----------------------------------------Infragistics2.Win.UltraWinDock.v9.2 Assembly-Version: 9.2.20092.2119. Win32-Version: 9.2.20092.2119. CodeBase: file:///C:/Program%20Files%20(x86)/Unitronics/SD%20Card%20Suite/Libraries/Infragistics2.Win.UltraWinDock.v9.2.DLL.----------------------------------------Infragistics2.Win.UltraWinGrid.ExcelExport.v9.2 Assembly-Version: 9.2.20092.2119. Win32-Version: 9.2.20092.2119. CodeBase: file:///C:/Program%20Files%20(x86)/Unitronics/SD%20Card%20Suite/Libraries/Infragistics2.Win.UltraWinGrid.ExcelExport.v9.2.DLL.----------------------------------------Infragistics2.Excel.v9.2 Assembly-Version: 9.2.20092.2119. Win32-Version: 9.2.20092.2119. CodeBase: file:///C:/Program%20Files%20(x86)/Unitronics/SD%20Card%20Suite/Libraries/Infragistics2.Excel.v9.2.DLL.----------------------------------------System.Xml Assembly-Version: 2.0.0.0. Win32-Version: 2.0.50727.5485 (Win7SP1GDR.050727-5400). CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll.----------------------------------------System.Design Assembly-Version: 2.0.0.0. Win32-Version: 2.0.50727.5491 (Win7SP1GDR.050727-5400). CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll.----------------------------------------System.Core Assembly-Version: 3.5.0.0. Win32-Version: 3.5.30729.5420 built by: Win7SP1. CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll.----------------------------------------Accessibility Assembly-Version: 2.0.0.0. Win32-Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400). CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll.----------------------------------------mscorlib.resources Assembly-Version: 2.0.0.0. Win32-Version: 2.0.50727.5485 (Win7SP1GDR.050727-5400). CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll.----------------------------------------System.Xml.Linq Assembly-Version: 3.5.0.0. Win32-Version: 3.5.30729.5420 built by: Win7SP1. CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml.Linq/3.5.0.0__b77a5c561934e089/System.Xml.Linq.dll.----------------------------------------Unitronics.DataTables Assembly-Version: 1.0.0.17. Win32-Version: 1.0.0.17. CodeBase: file:///C:/Program%20Files%20(x86)/Unitronics/SD%20Card%20Suite/Libraries/Unitronics.DataTables.DLL.----------------------------------------System.Data Assembly-Version: 2.0.0.0. Win32-Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400). CodeBase: file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll.----------------------------------------Xceed.Compression.Formats Assembly-Version: 3.7.8577.11540. Win32-Version: 3.7.8577.11540. CodeBase: file:///C:/Program%20Files%20(x86)/Unitronics/SD%20Card%20Suite/Libraries/Xceed.Compression.Formats.DLL.----------------------------------------Xceed.Compression Assembly-Version: 3.7.8577.11540. Win32-Version: 3.7.8577.11540. CodeBase: file:///C:/Program%20Files%20(x86)/Unitronics/SD%20Card%20Suite/Libraries/Xceed.Compression.DLL.----------------------------------------Unitronics.ComDriver Assembly-Version: 1.0.0.61. Win32-Version: 1.0.0.61. CodeBase: file:///C:/Program%20Files%20(x86)/Unitronics/SD%20Card%20Suite/Libraries/Unitronics.ComDriver.DLL.----------------------------------------System.Windows.Forms.resources Assembly-Version: 2.0.0.0. Win32-Version: 2.0.50727.5420 (Win7SP1.050727-5400). CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_de_b77a5c561934e089/System.Windows.Forms.resources.dll.----------------------------------------UniDBServices Assembly-Version: 2.0.10.0. Win32-Version: 2.0.10.0. CodeBase: file:///C:/Program%20Files%20(x86)/Unitronics/SD%20Card%20Suite/Libraries/UniDBServices.DLL.----------------------------------------************** JIT-Debuggen **************Um das JIT-Debuggen (Just-In-Time) zu aktivieren, muss in derKonfigurationsdatei der Anwendung oder des Computers(machine.config) der jitDebugging-Wert im Abschnitt system.windows.forms festgelegt werden.Die Anwendung muss mit aktiviertem Debuggen kompiliert werden.Zum Beispiel:<configuration> <system.windows.forms jitDebugging="true" /></configuration> Quote Link to comment Share on other sites More sharing options...
Saragani Posted August 3, 2015 Report Share Posted August 3, 2015 Hi, in order to fix this issue, I will need the udt file, since this problem doesn't happen on the files I've checked. Thanks Quote Link to comment Share on other sites More sharing options...
