Jenkins Posted August 14, 2015 Report Share Posted August 14, 2015 Hello all, I have an application with only a few screens. I am using TightVNC Viewer per Tech Support. I have a UDP Socket configured for Port 555 in the UniLogic project and am not using any security for the VNC configuration. I am connecting to the IP Address of the Panel which is different from the Panel. The ethernet cable is connect directly from the computer I am working on. Am I missing something? Are there setting that need to be configured yet? I have attached screenshots of my VNC settings and the message when it closes, Any help is much appreciated! Jenkins Quote Link to comment Share on other sites More sharing options...
Alexander Posted August 14, 2015 Report Share Posted August 14, 2015 On the Connection screen, try changing the preferred encoding setting from Tight to Hextile. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted August 14, 2015 MVP 2023 Report Share Posted August 14, 2015 Also try checking the "256 colors (less traffic)" box. Quote Link to comment Share on other sites More sharing options...
Jenkins Posted August 14, 2015 Author Report Share Posted August 14, 2015 Thank you! I used the settings you both suggested and it is working consistently. Jenkins Quote Link to comment Share on other sites More sharing options...
