romario86
"Fill Array Part" Ladder function
Hello,
could you help me please, I have function fill array part, I can not to find in help how can use it.
In help are no information about array function. Old VisiLogic was more simple in this,
Thank  for help
You can always use the Ladder function "ears" tool-tip in order to understand better the function. The tool-tip visible when hovering with the mouse courser over the ear. In "Fill Array Part" case:
A  -  Array (destination), The data is written into this array
B  -  Offset in array
C  - Operation (insert or overwrite
D  - Value to use.
E  - Number of times to repeat operation
Starting from next version, you will be able to  get a contextual help in most of the Ladder Elements the same way you can get  it for HMI elements.
(A blue question mark will appear next to each ladder element name in the Ladder tool box when you hover it)
