2rlp Posted January 19, 2011 Report Share Posted January 19, 2011 Hi, I am using Win XP SP3. I have just installed V9.0.1. Whenever I try to use it, I get the error as per PDF attached. Thanks for your replies Ron V901.pdf Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted January 19, 2011 Report Share Posted January 19, 2011 Dear Sir, Apparently you have some DLLs that need to register. Try to open the swapper tool and choose VisiLogic_C folder from Program file>Unitronics and register the version. If it's not helping, try to reinstall VisiLogic as follow: Backup your application files. Uninstall VisiLogic. Erase the “Unitronics” folder from- C:\Program Files Erase the “Unitronics” folder from- C:\Program Files\Common Files. Install VisiLogic again. Cheers, Quote Link to comment Share on other sites More sharing options...
2rlp Posted January 20, 2011 Author Report Share Posted January 20, 2011 Thank you very much. All I needed to do was to register it in the Vision Swapper. Ron Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted January 20, 2011 Report Share Posted January 20, 2011 Dear Ron, Thank you for your feedback! BR, Reuven Quote Link to comment Share on other sites More sharing options...
