olivier Posted January 19, 2011 Report Share Posted January 19, 2011 hi, there is no choice to select the V350 -35-Tu24 in the new version of visilogic is this an incompatibility or an oversight thank you Olivier Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted January 19, 2011 Report Share Posted January 19, 2011 Dera Sir, In C:\Program Files\Unitronics\Unitronics VisiLogic_C\Data\HW Cfg\Elements List….you will find a file called ElementsList.ini Please enter the file and add V350-35-TU24 to V350 list. Goodn luck! Quote Link to comment Share on other sites More sharing options...
olivier Posted January 19, 2011 Author Report Share Posted January 19, 2011 i found that since i post ;-) ... thank you Quote Link to comment Share on other sites More sharing options...
